Truck rig
fredrik
Truck rig
Post by fredrik » Tue Jul 22, 2008 3:33 pm
I am using the 4WheelerExt (Director Tools 1.8.1 in Maya 2008 32-bit) to create something similar to a Peterbilt with trailer.
I'm just going through the 4WheelerExt manual but any tips or pointers would be much appreciated. Are there any tutorials around on rigging a truck with trailer?
Right now I am wondering if it matters that I move the rig's wheels outside of its body (I cannot scale the body as it is the top node)... or if that would be a bad idea for any reason...?
Fredrik Averpil,
VFX Supervisor, Filmgate
Re: Truck rig
Post by Patrik Martin » Tue Jul 22, 2008 5:11 pm
Hi and welcome to our forum Fredrik!
A tip is to check out the Craft Trailer manual as well. This manual is more aimed for semi truck trailers.
Trailer manual
I also made a picture set of how I would rig one of those trucks:
As you can see in this image the 4-Wheeler (Extended) has its rear wheels behind its chassis. You can scale and move the wheels of the 4-Wheeler nearly as much as you like. If you don't want the rear wheels to turn, remember to also move the TurnBaseMesh.
fredrik
Re: Truck rig
Post by fredrik » Thu Jul 24, 2008 12:17 pm
VERY nice!
Thank you! :)
Fredrik Averpil,
fredrik
Re: Truck rig
Post by fredrik » Thu Jul 24, 2008 3:14 pm
My highres trailer model that I've got is way much more wider than the Craft trailer. I'm trying to simply move the craft tires out but the weirdest thing happens ...
(save link as... + open in Quicktime player)
Fredrik Averpil,
Re: Truck rig
Post by Luigi Tramontana » Thu Jul 24, 2008 3:51 pm
Hi Fredrik.
Yes this is an issue. The simple solution is to scale the trailer so that it fits your wheels width, then you will have a stable situation (and of course you need to move the hook to the same point as before).
Good luck!
fredrik
Re: Truck rig
Post by fredrik » Thu Jul 24, 2008 5:08 pm
This works nicely.
Fredrik Averpil,
solomon
Re: Truck rig
Post by solomon » Thu Jul 31, 2008 3:45 pm
Would the above solution apply to a model like this?
_________________________________________________________
Solomon W. Jagwe
3D Artist | Animator | Modeler
Soreel GraFx | http://www.sowl.com
http://solomon.cgsociety.org
Re: Truck rig
Post by Luigi Tramontana » Thu Jul 31, 2008 11:13 pm
Hi Solomon.
The latest version of Craft Director Tools (released 2008-08-11) solves this problem:
- It enables a vehicle to have a much larger turn angle on the wheels and therefore this type of 8-wheeler rig is possible together with ExtraWheel.
- The suspension should be quite stiff.
- For the turret you should use two 1DRotators and a FirePower (and in the 4wExt you choose as input the firePower's virtual input to drive the external force, also parent the externalForceMesh to the turret).
// Luigi TA
solomon
Re: Truck rig
Post by solomon » Tue Aug 12, 2008 5:10 am
WOW!!
Awesome!! I am so glad I asked - I will definitely give that a try. Thanks Luigi
Solomon W. Jagwe
Cheshirsky
Re: Truck rig
Post by Cheshirsky » Sun Aug 17, 2008 11:45 am
O-Goh! Thx gentlman's! :)
BradFred
Rigging a truck and trailer tutorial
Post by BradFred » Fri Dec 04, 2009 7:01 pm
I am rigging a truck and trailer, I had planned on using the TRuck and trailer template in CDS 9.31 but my model does not fit, is there a tutorial to doing this. Can I scale all aspects of the template? Basically I will be tipping a tanker truck, and ideas where to start?
Re: Rigging a truck and trailer tutorial
Post by Carl Buhre » Mon Dec 07, 2009 1:18 pm
BradFred wrote:I am rigging a truck and trailer, I had planned on using the TRuck and trailer template in CDS 9.31 but my model does not fit, is there a tutorial to doing this. Can I scale all aspects of the template? Basically I will be tipping a tanker truck, and ideas where to start?
If you want to use the template you can just scale it to the size you want (make sure to scale using Object Mode, if you're using CINEMA 4D). You can also view the turbo video tutorial for Craft Trailer here: Craft Trailer Turbo Tutorial
BradFred
Re: Truck rig
Post by BradFred » Mon Dec 07, 2009 4:13 pm
What is funny is that you have an animation of the semi-truch and trailer that I am using 3d animation Craft Director Tools (truck & trailer). I was wondering is these was a tutorial using tht truck and trailer?
Re: Truck rig
Post by Carl Buhre » Mon Dec 07, 2009 4:21 pm
BradFred wrote:What is funny is that you have an animation of the semi-truch and trailer that I am using 3d animation Craft Director Tools (truck & trailer). I was wondering is these was a tutorial using tht truck and trailer?
BradFred,
Which animation are you referring to? But to answer your question, I'm pretty sure we don't have any tutorials for rigging a semi-truck, unfortunately. It's not that hard though, just create a Craft 4-Wheeler Extended, load the truck configuration profile for it, create a Craft Trailer and rig it as instructed by its help documentation and then just add Craft ExtraWheels for the remaining wheels and you're set.
BradFred
Re: Truck rig
Post by BradFred » Mon Dec 07, 2009 5:22 pm
I will give it a shot. There is a video on youtube of a semi truck and trailer driving around on a white floor.
Re: Truck rig
Post by Carl Buhre » Tue Dec 08, 2009 8:54 am
BradFred wrote:There is a video on youtube of a semi truck and trailer driving around on a white floor.
This one? http://www.youtube.com/watch?v=4Ub4OKZqxd8
It's user-created, not something we've done. But let us know if you have any questions during the rigging process. You should be able to find most answers in the help documentation though.
Users browsing this forum: No registered users and 117 guests
