SoftMotionCam
alexfrancisva
SoftMotionCam
Post by alexfrancisva » Tue Jul 21, 2009 4:10 pm
Hii.. im using maya 2008 64bit. When using the craft softmotion cam, its creating the cam at scale 100,100,100. So i selected the group(SoftMotionCam_01_AttachedCamTransform), and scale down to 1,1,1. When i press record, only the followcam(not attachedCam) suddenly jump to Scale 100,100,100. But on the first frame its 1,1,1. from the second frame its 100,100,100. i done it again by scaling down, but result is the same. Do you have any suggestions to fix this scale at 1,1,1? I also have the same problem with sphereCam.
Re: SoftMotionCam
Post by Carl Buhre » Mon Aug 17, 2009 8:43 am
alexfrancisva wrote:Hii.. im using maya 2008 64bit. When using the craft softmotion cam, its creating the cam at scale 100,100,100. So i selected the group(SoftMotionCam_01_AttachedCamTransform), and scale down to 1,1,1. When i press record, only the followcam(not attachedCam) suddenly jump to Scale 100,100,100. But on the first frame its 1,1,1. from the second frame its 100,100,100. i done it again by scaling down, but result is the same. Do you have any suggestions to fix this scale at 1,1,1? I also have the same problem with sphereCam.
Did you try to scale its parent as well? Since in Maya, children inherit scale.
Users browsing this forum: No registered users and 253 guests
